i sometimes have a problem converting avi with tmpgenc. While converting to mpeg-2 TMPGEnc stops and I get an error message that reads "Index of scan line is out of range(240). How can I correct this error and successfully convert avi. I attempted to use virtualdub to fix avi but virtual dub also gives me an error. Please help
Where did these error-filled avis come from ? Did u cap them ? If so, explain how. If tmpgenc and Vdub both get errors, the avi may be damaged.
I have this same problem, but I am new to this and have no idea where to start to fix it. I have VirtualDUb but thus far have only used it to check fram rate. ANy sugestions would be great. Thanks
the movies came from irc. i usually dont have problems with them. what wiuld you suggest i do to avi. I can play avi on windows media player but cant encode.
I run into this problem often. Regardless where they are downloaded from, they are Divx movies, normally from Kazaa. But This only happens when the movie has some bad sectors in it in which I tried to fix using DivxFix. When TMPGEnc tries to encode, it goes straight to this error message.
Any suggestions? -
I have this same prob...
if I get it by the error...then I get audio synch probs...so I just find a SVCD source and don't mess with it...
some advice, huh? -
You can also get around a bad/corrupt AVI by frameserving it to TMPgenc, using VirtualDub, AVISynth, or whatever server you use. It's an easy solution.
Impossible to see the future is. The Dark Side clouds everything...
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 22:00 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 12:05
