After I reinstalled windows ( clean install) i'm not able to view certain mpgs anymore. When I play them using xing, wmp, or power dvd, the video comes up scrambled or the player just crashes. Nothing is wrong with the mpgs because I use to be able to play them. I guess I'm missing some codecs and/or drivers, can anyone help?
They are "probably" MPEG-2 videos, which Windows does not, by default, contain the drivers for. You need to install whatever software you had before, that you used to watch DVD's.
Getting two fatal errors when extracting mpgs from vobs
By Antony in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Apr 2012, 00:24 -
Several movs/mpgs to DVD / Quality decreases on best files
By soundchaser in forum MacReplies: 4Last Post: 2nd Nov 2010, 10:04 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 22:37 -
Join several mpgs together
By milway in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 20:49 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 13:35
