  1. im pretty new to using BIN files when burning and i just had a a couple of questions.
    First one is if you have a software BIN file larger than your cd space (750mb file, 700 mb cd) can you acually burn it onto it?
    Secondly if you can do it how? just liek a normal bin file or is there something extra you have to do??
    I hope this is the right place for me to post this thread, im not sure where if this isn't right, so sorry in advance.
    Seaside, CA
    CD's are rated for their mode-1 capacity. An 80min cd can hold 700meg mode-1. VCDs, CVDs, SVCDs, etc are recorded mode-2. In mode two that same CD holds 800meg of data. Thereby that 750meg image file will work fine with your 80min/700meg (mode-1) cd because it will actually be recorded mode-2 (800meg.) Yes, you burn it just like a normal bin file. Some of the burning programs need to be configured properly for 800meg disks. After trying a while with Nero, I gave up and started using VCDEasy. If you decide to use VCDEasy you may have to install the ForceASPI drivers to get it to work.
