  1. I am creating a Loop DVD to play in my VideoSTore with movie trailers on it. So I capture all of the MPEGs from my SVHS and then I create a storyline and fade them in and out and blah blah blah. So then I create a MPEG file. 1 big one. I am using Ulead Video Studio 6 to create my MPEG files.
    So then I use Ulead DVD Workshop to create my menus and then I create an ISO file with the Video TS and Audio TS files.
    Then I burn them using Nero.
    SO I pop it into my DVD player and its only playing out of one speaker!? The left one! And when i try to change the balance to the far right, I dont get any sound!
    CAN ANYONE HELP ????
    PLEASE!
  2. When you preview the files off the timeline in vs6, is the sound messed up? Do the mpegs that vs6 makes have the problem? do they have the problem when you preview them in DWS? Have you determined the point in your process where the sound goes haywire and you lose a channel?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. They sound fine on my computer! No problems at all. And the audio goes funky as soon as it starts!
