    Nov 2000
    Fairless Hills
    I searched the site for it but befor I get blasted I could not find it. I read it a while back , is there a way to make seamless chapters in VCD preforably because I don't use svcd. I think it was a tutorial with Iauthor. Well I use Roxio WinOn 3.8 I also use Cequadrats WinOn 3.7PE and Video Pak 4.0. I have Nero 5.5.2.9 also. Well I have done multiple menues with WinOn 3.7PE, I'd like to give it a more DVD feel with seamless chapters. Is this possible with *VCD* or even svcd? ANy help most greatfull, Again I did do a search before I post=)
  2. Yes, this can be done with both VCDs and SVCDs.
    If you have VideoPack 4, you can do it already. You will have to use "entrypoints".
    You can use I-Author, but the version commonly floating around can only do SVCDs.
    VCDImager can also create entrypoints for both VCDs and SVCDs and is the freeware and open source alternative.
    Regards.
    Michael Tam
    w: Morsels of Evidence
