For some reason every backup that i make has pixelization specs every so often. is this normal. I am using a DRU500A and using VERBATIM -R and using Stomp record now max. I have burned at both 1 and 2x and run into the same problem.
question, what program did you use to rip ??did you tried to transcode the movie?? what program???
lol.. since u dont know what transcoding means...you probably didnt have to do it...which means if all u did was rip a dvd with smart ripper and then burn it to a dvd-r your problem probably is your dvd-r media.
u might need to try a different brand of dvdr media as some are really low quality..also try burning at 1x if u use faster speeds that might help.
but i think your problem is with the media..try something different and see how that works!!check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Lots of pixelization on capture
By sum_guy in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2011, 21:01 -
Pixelization of Edges of Objects in a Scene
By Gary Dillon in forum Newbie / General discussionsReplies: 6Last Post: 14th Mar 2010, 11:55 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 15:45 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19
