hi.. I read the tutorial for cutting and joining movies with VCDCutter and it says that VCDCutter doesn't make compliant VCDs. Does that mean the VCD cannot be played on a standolne VCD/DVD player?
thanks
A non compliant VCD would be a Xvcd.Originally Posted by jimot
Check the list of DVD Players to the left and see if your player can play Xvcd.
If your DVD can play them (and you use Nero to burn) ,make sure the non-compliant box is checked or unchecked."Today is only yesterdays tomorrow"
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 19:06 -
Scene Detection and Cutter for MPEG File
By klode in forum EditingReplies: 6Last Post: 6th Nov 2011, 18:39 -
VCD Cutter
By devilcoelhodog in forum EditingReplies: 0Last Post: 16th Jan 2010, 15:39 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 15:35 -
easy mpeg 1/2 cutter?
By ecc in forum EditingReplies: 2Last Post: 7th Oct 2007, 09:17
