Anybody have this problem with certain movies. I had it with "Cast Away" It is a region 1 DVD. I ripped it to the hard drive. I started the decoding process with DVD2MPG Squeezer and the region screen popped up. But When I encode straight from the DVD it works. Do I have to edit the .ifo file?
I think you have to click the "region free patch" in "settings" with smartripper when ripping to your hard drive - that's if you use Smartripper. If you use other ripping software check that it has a similar feature.
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Runtime Error playing back ripped DVD folder
By oshanruiz in forum DVD RippingReplies: 0Last Post: 14th Jul 2011, 11:15 -
error recording a region of screen
By George2 in forum Newbie / General discussionsReplies: 3Last Post: 30th Jun 2009, 12:21 -
Samsung BD-P1500 - error when trying the region code hack
By Clown in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th May 2009, 18:05 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
