  1. I have a WinTv Go card with the Bt878 chipset and i use the sourceforge drivers and it works very well. But when ever i try to cap in v-dub my audio is always out of sync. I use the Picvideo mjpeg codec and uncompressed audio. I used the guide on this site to set evreything up and even tried the sync fix on it but it does'nt work. This only happens in v-dub though. It even happens when there are no lost frames. It happens with the composite input and cable input.
    And another thing, this isnt a problem but i seem to get stereo sound even though im using the built in tuner. On the box it says mono only though. Could this be because of the Source Forge Drivers? This isnt a bad thing but i just though it was kinda wierd.
    And on final thing, i have Vegas Video 3 and ive used the video capture in it to capture from the card but it's in DV. Does anyone know how to use the mjpeg codec in it? Thanks
  2. Try updating drivers. Also, try the "lock audio stream to video" setting in virtualdub ... prefs, I think.
