My friends computer doesent have enough ram to use XP so I am trying to install 98se. So Im trying to boot from the cd rom drive. I have done this befor but not on this old of computer. I get the options "boot from A,C) I can chang it to C,A but im not shure if this is right?
Results 1 to 9 of 9
*pardon my english, I dont take the time to type right.*
___insert witty, well writen, thoughtthrough comment here___ -
You need to go into the bios and select the CD drive as the first boot device. If it is a really old pc and this option isn't in the bios you may be able to update it, check on the motherboard manufacturers website for possible bios updates.
That isnt an option. I cant log onto the computer. The two HDDs That are in the computer are an 8gb (master) and a 20gb (slave) these were given to me and there was somthing wrong with the OS on the drives. So what I want to do is delete everything on both drives then install windows 98se and start from scrach. I cant log onto windows because there are to many windows files missing from the drive to boot.
bootdisk.com get a bootdisk (floppy) of the operating system you're trying to update from and put the Windoze 98se cd and the floppy at the same time, this is the way i reinstall windows when my PCs fall from perfection
The Windows 98 disks are not bootable! You will need to go the bootdisk method. If the drives were NTFS, then you will need to run fdisk, and delete the partitions, then format & install.
You will most likely need a bootdisk that has generic CD drivers, or you will not be able to access the CD drive.
I just went though this with one of our union computers. I've been in NT land for so long, I forgot how to use fdisk! I would spell it out for you, but, I just mungled my way through it! :PSteve
Frozen in the North -
Coldplay
My windows 98se disk is bootable.
Sonkun
You dont need for the operating system to be operational to get into the bios and make the CD drive the first boot device. With most bios's you press either del or F1 after turning the PC on. -
But, my "Me" disk is not... Go figure. Then, it is an upgrade, but so is my WinXP Pro & Home, and my Win2k, and they all are bootable.
Oh well, I'll go home now! 8)
*It is not THAT cold up here!*Steve
Win 98SE and Win ME disks are bootable if you are talking about the floppies for bootdisk and both have generic cdrom drivers
I still havent figured out how to make a boot floppy for xp -
No, we're taking about bootable CD-ROMs.
I don't have a WinME disc but my Win98SE CD is bootable as well (as is my WinXP).
You can make a bootable floppy under WinXP by formatting a floppy and clicking on the transfer system box... However, this is much less useful under WinXP, especially if you use NTFS as you won't be able to access the HDD.
Realistically, a CD drive that you can boot off (which should be ALL PCs that even have a chance of running WinXP) is a must. If you really screw up your PC, you can boot off the WinXP CD and use the "Recovery Console".
Regards.Michael Tam
w: Morsels of Evidence
How do you boot into a Linux Partition from a USB Flash Drive?
By Number Six in forum LinuxReplies: 10Last Post: 16th Feb 2009, 15:20 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 17:19 -
Best Way To Move Boot Drive To New Board?
By DarrellS in forum ComputerReplies: 38Last Post: 15th May 2008, 11:53 -
HELP! reactivating SATA drive everytime i boot?
By JayArea408 in forum ComputerReplies: 3Last Post: 2nd Sep 2007, 16:12 -
slave drive seems dead, but cannot boot without it
By ted demen in forum ComputerReplies: 11Last Post: 13th Jun 2007, 07:54
