Hi, everybody - second attempt at a post. I have just bought a Schneider DVD 1003 player from Asda in the UK. I would appreciate any info on multi-region hacks for it, and any other info on what I can/cannot play on it. The destructions are a bit contradictory on the latter. The machine performs very well with a standard region 2 DVD, delivering a crystal clear picture and excellent quality sound.
Thanks for your help
Steve
i used the pacific 1002 hack and it worked fine. This machine also outputs PAL so an NTSC tv is not required. I set my tosshie to ntsc to test and the pic is b+w but ok if PAL.
It played an R1 Goldmember DVD (purchased from Florida) perfectly.
The following hack works on the latest machines
on the remote
press open/close
press clear
press 1
press 3
press 6
press 9
press region number 1 to 6(0 for region free)
press open/close
Hopefully you are now region free -
The following hack worked on a schneider 1003 (from ASDA)
on the remote
press open/close
press clear
press 1
press 3
press 6
press 9
press open/close
hi steve... i thought i was the only person in the world looking for hacks and info on the mysterious schneider 1003. there is one left on display at asda i can buy for a song but i 'd like to know it's capabilities first and there is no information to be had anywhere! can you enlighten me on the subject? how did the hacks go down? does it play mp3 vcd svcd or cd even? the store have zero info too?
Help with LG RC389H DVD player hack
By nannon in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Jul 2010, 06:04 -
Is there a way to hack a Chrysler DVD player?
By Kiannshysmom in forum DVD & Blu-ray PlayersReplies: 9Last Post: 18th May 2010, 23:13 -
DVD Player Hack
By jgibson in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2010, 20:48 -
NON-region DVD player hack...
By cwb in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Sep 2009, 17:53 -
dvd player hack seems to have gone wrong, any help?
By johnkurtz in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th May 2009, 16:09
