ok ive done everything step by step from turning a avi to a vcd and it still wont work.i used this guide and did it exactly.
http://www.vcdhelp.com/divxtovcd.htm
now when i finish burning a box pops up and says this'
"CDRDAO disk info execution failed"
here is the log i copied from vcdeasy of the burn,incase this tells someone what the problem is,igot this wednsday morning and have been trying to burn a cd since then,i have not made even 1 that plays,i would really appreciate some help.here is the info vcdeasy gave me out of the log.
[Internal Xml Generation]
Internally computed XML generated successfully as "C:\WINDOWS\Desktop\fridaypart1.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `VIDEOCD'
changed publisher id to `VCDEASY_V113'
changed application id to `CDI/CDI_VCD.APP;1'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, C:\WINDOWS\Desktop\2002tmdrecruitpack\tmdinvision2 \tmdinvision2\Download\[TMD]Friday.After.Next.(PMTVCD).Subbed.TS.(1of2).mpg
strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)
pts start offset 0.340078 (max pts = 2375.479511)
playing time 2375.139433
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 32 (extended psd 56)
iso9660: highest alloced sector is 257 (using 300 as isosize)
writing track 1 (ISO9660)...
writing track 2, MPEG1, NTSC SIF (352x240/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 148708 video, 29183 audio, 0 zero, 0 ogt, 263 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 178829 sectors [39:44.29]
[CDRDAO Disk Info]
Cdrdao version 1.1.7
1,0,0: HP DVD Writer 200j Rev: 1.13
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
That data below may not reflect the real status of the inserted medium
if a simulation run was performed before. Reload the medium in this case.
assertion "lba >= 0" failed: file "Msf.cc", line 48
CD-RW: yes
Total Capacity: 316 [sig] cdrdao 355527 open_stackdumpfile: Dumping stack trace to CDRDAO.EXE.stackdump
and i am putting this on a dvd+rw disk,i have a hp n5250 pavillion labtop,hpdvd200e burner and its connected by firewire if that helps
Firstly, read this: http://www.vcdhelp.com/vcd
VCDs are exclusively CD based.
You cannot burn a VCD onto DVD media.
Secondly, CDRDAO (which is the burner that VCDEasy uses) cannot burn to external drives ... not that you can burn a VCD image to a recordable DVD anyway.
Regards.Michael Tam
w: Morsels of Evidence -
thanks for the info,i just spent almost 500 on all this stuff and i was geting irratated cause i have had nothing but problems since i got it.thanks again for the help
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Burning TS file to DVD and playing in a Blu-Ray player
By robertazimmerman in forum Authoring (Blu-ray)Replies: 4Last Post: 9th Nov 2010, 12:04 -
Burning DVD using ConvertXtoDVD - rating problem when playing?
By mistyfog in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2009, 10:28 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
converting, burning, and playing avi files
By unionman4077 in forum Video ConversionReplies: 1Last Post: 27th Feb 2008, 17:01
