  1. Hello, I´ve downloaded the new version of the EasyVCD (1.14) and the ASPI for XP (I´m using XP Pro) reboot the computer and followed THE instructions to rip a region 2 (Gosford Park) new DVD. When I press the rip it bottom after the DVD scan, I get Run time error 5 Invalid procedure call or argument. it looks like if it does not scan the dvd correctly, and this happens with every dvd I try to rip. I´ve installed the program a couple of times, bat the problem persists.
    What can I do?
    Thanks in advance.
    Carolech
  2. Can you please tell me what it says in teh "Program Chain" and the "Audio Track" fields.
    DVD to VCD made eazy
    http://www.eazyvcd.tk
  3. oh, and also.......
    after Eazy VCD finished scanning the DVD disc, did it give you a message that said "Some of the DVD Files are still locked, Try to unlock with a software player and rescan the dvd." ?
  4. Carolech,
    Coincidentally, I had a similar problem with Gosford Park (my copy was Region 1). Using EazyVCD 1.12 I was able to rip but not convert all but the last vob file.
    My experience is that maybe one of twenty DVDs won't rip for me. I just go on to another DVD and don't waste a lot of time trying to rip a problem disc. Oddly, it's not always the big hit that won't rip. Gosford Park was one example.
    I liked the movie (Gosford Park) well enough to buy it (cheaply) off eBay.
  5. 1 in 20 :-? ?
    frig, i've riped well over 200 DVD's and never had an "uncopyable" DVD yet.
    ACCEPT NO LESS THAN 100%
  6. Rob,
    Two hundred DVD's is a lot of ripping, especially considering how much time you've devoted to developing EazyVCD. Obviously I've got a lot of catching up to do...
    Some irksome DVDs give up after a struggle, but for me the struggle simply isn't worth it. I simply move on to another, more compliant, DVD.
    Thanks for such a great program. I've contributed to it and hope to send more in the future --
  7. yes, well....I'm a bit stubourn.
    If i have a problem with a DVD, it just makes me more deturmond to copy it.
    the worst one I every copied took me 3 days
    but i did it
    glad you find good use in Eazy VCD, and thanks for your support.
    also there is also a new updater at http://members.eezi.net.au/~phatjeff/EazyVCD114_to_114c_updater.exe
    it will update version 1.14 and version 1.14a to version 1.14c
    just fixes a few little bugs
