i finally got my dad to properly hook up my friends's tv card to my pc and it was playing Nick Replay [sky channel] no problem, great quality, looked exactly like tv, then the program crashed and i had to re-install it and when i tried to turn it on again and the frame rate was really low and all the pictres were jerking and stuff, any idea how to fix it? i installed the TV Card 3 weeks ago but couldn't get a signal so while i was thinking out how to get one i was playing about with the options so i think i clicked something that made the quality great, but it obviously it isn't the default settings, as the default settings make it jerky and stuff, if anyone has any idea of a possible solution to this i'd really appreciate it, thanks!
Results 1 to 1 of 1
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
