hi all how is capping at 352x480 and then encoding at 352x240 any different than capping at 352x240 from the get to? will the quality be better if i cap at 352x480 and encode at 352x240? i am making a vcd. but i have read tons of posts that say if your gonna make vcd cap higher and then resize down? thanks
Originally Posted by hoola_loop
If you only capture 1 field per frame, you are losing up to HALF of the video data!!
Capturing at the full vertical resolution (and then resizing down +/- deinterlace) looks noticable better and what you should notice is that the picture is sharper and there is relatively less video noise.
Regards.Michael Tam
w: Morsels of Evidence
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
