Forgive me, as I posted this message in the hardware formum about a week ago and did not get a lot of feedaback. I am hoping someone might be able to help me here.
I purchased a Panasonic DMR-E20 several months back for the purpose of transferring old high school football games from VHS to DVD.
For the most part, it has worked flawlessly. However, there have been a couple of videos where the DVD recording has not matched the quality of the VHS source. These quality issues include: cloudy picture and color that is not as bright and crisp as original source.
The output of my VHS plugs directly into the input of my DVD recorder via RCA cables (I even went out and purchased $50+ cables). The signal is then output from the DVD recorder to my TV, so I am able to monitor the source while I record. I have attempted to record on all possible quality settings, but still have the problem.
It would make much more sense if it happened with all tapes, but it only occurs on a few of them. How it is possible that the DVD recording does not exactly duplicate the VHS source that I am able to view on the TV screen as I am recording.
Is there a setting in the DVD recorder that can fix this problem?
Thanks in advance for any advise you might be able to provide.
Rich
Rich,
Sounds like those VHS tapes have macrovision on them to prevent copying. Just my guess.
Dave
LG Rh399 Timer Recording from AV Input
By Bashar in forum DVD & Blu-ray RecordersReplies: 5Last Post: 18th Jul 2013, 02:08 -
Recording 2 Wired mics with only 1 mic input...
By clarkkwgriswold in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Apr 2012, 17:51 -
Getting the dvd recorder input incorporated into the mix for recording
By duckman in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2010, 00:41 -
multiple line input on pc - recording radio
By straighjacket in forum AudioReplies: 1Last Post: 8th Feb 2009, 17:36 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 12:39
