I have this game Mafia. Its 2 .bin files. One is 790 MBs and the other is 754 MBs. I use CDRWIN 5 to burn them to a cd but my question is will these fit on a 700 MB cd-r? They are quite big. Is there a way I can open them and see what they contain? Any suggestions?
Firstly, I hope that you have the CUE files as well as otherwise, you may have some problems.
The images will "probably" fit onto an 80 min CD (without overburning) -- I'm assuming that the CUE/BIN images are in "raw" mode (i.e., 2352 byte sectors).
Regards.Michael Tam
w: Morsels of Evidence -
Hi no it didnt come with a .cue
I downloaded another game a while ago and it only had .bin file so i used CDRWIN and it worked fine with no problems. But that was only like 540 some MBs. This has two files that both exceed 700. At the moment I dont have any cd-rw's to test it on so i'll just use a cd-r and see if it overburns or fits even.
bin subtitles
By smittenjey in forum Authoring (VCD/SVCD)Replies: 4Last Post: 7th Jan 2011, 15:20 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Recycling Bin
By Nitro89 in forum ComputerReplies: 6Last Post: 20th Feb 2008, 08:02 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05
