I am trying to create a so called 'simple' menu in Nero, however the 'background picture' function does not work, when the VCD is burnt and put in the DVD player, the background resembles nothing of what the picture actually looks like.... For example on The Exorcist VCD, i put a JPEG image of that eevil statue in the background, but when played on DVD player, it dosent even show a picture, it just shows a mix of blue and bright green colors randomly scattered about the background... This isnt because of the DVD player, because its the same on a VCD player.. Does the background picture function only work for certain types or certain sizes of pictures?? If so, what are they?
Mitch
It might be a problem Nero is having with your burner...
Have you tried using VCDEasy?
Regards.Michael Tam
w: Morsels of Evidence
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 11:58 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 14:48 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 06:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 13:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46
