Hi...i'm bother by the problem about the my stupid PS2 not reading my dvd-r discs...I don't know why it happened now but it was working fine a few months ago and now when I put it it and it can read in the Browser but when it start to read it goes into a black screen and said " Unable to read disc"...Can anyone in here can help me out...I have burned lot of my dvd-r and I really hate to throw them all away just because of that...I spend lot of $$$ on those discs...Any suggestion will do...I'm very despressed rite now. Thank you
hey, maybe you need to update your DVD drivers. I had this exact same problem with my PS2 not too long ago and when I updated my drivers my DVD-R's were playing just fine.
If your PS2 used to play DVD-R's then the problem is most likely the laser calibration, if you think you have the skills to adjust it your self then there is a guide here. This link also has info on some other neat stuff you can do with your PS2 like playing VCD's (yes it is possible but probably not worth the hassle since you have a DVD burner
Compatibility reports can be found here along with information on which models of PS2 work with what media.
The driver update mentioned by wakuwaku may solve the problem but it is best to get as much info as you can before trying anything.
Good Luck
OddbOd -
trust me I had the same problem. Is your playstation 2 down flat? For some reason its works much better when its on its side, just put it on its side and it should work.
Thank for all the replies...but where can I find a PS2 updated driver. I don't know if you guyz read my message but I mentioned that my PS2 read my dvd-r but when I press X-enter, it goes to the black screen and it said "unable to read disc" why is that happened??
Camcorder doesn't read SD card!
By Dawood1987 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 14th Apr 2014, 07:25 -
DVD-ROM doesn´t read DVD
By jsilv in forum DVD RippingReplies: 11Last Post: 7th Mar 2010, 07:43 -
My computer doesn't read dvd+rw disk
By jayjayj2 in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2008, 13:05 -
AOpen DUW1616/ARR doesn read DVD type disks
By phill in forum Authoring (DVD)Replies: 5Last Post: 9th Sep 2008, 20:46 -
DVD player doesn't read DVD
By hockey_fan_12 in forum Authoring (DVD)Replies: 1Last Post: 17th Nov 2007, 19:29
