  1. Hi, im using EazyVCD 1.14 to rip the music video "Hero" from Chad Kroeger off the Spider-Man DVD. Ok i created a 70MB SVCD, and when i played in PowerDVD everything is perfect, then when i use nero (with "standard compliance off") to burn it on a Imation 80Min CDR it starts to skip some frames, kinda like lag. I tried a different CDR but that also didnt help, and i burned at 4X. I tested it on a Apex and Panasonic but same thing. Help!
    Thanks in advance
  2. Some DVD Players just do this with SVCD, try just a VCD instrad
    DVD to VCD made eazy
    http://www.eazyvcd.tk
    Nov 2002
    A very small village.....
    My Apex use to do that as well, but when i started encoding my svcds with a resolution of 352x240 instead of the 480x480, the skipping stopped for some reason.
  4. Originally Posted by HeatoN
    Thanks in advance
    why you burn w/ standard compliance off???? you should make a standard compliant SVCD first.... if that doesn't play well on your apex, then it's prolly the player.
    btw, did the problem happen when you played the CD-R on your computer or only in standalone dvd player?
  5. O, well ill try to do both of those. Thx
  6. Hmmm well now ive tried it with compliance on, and now on fuji film cd. Ive downloaded some svcd's but they play fine, only the ones i rip skip frames (lag). And ive also tried it on my friends dvd player and it skips some frames too. Any more suggestions?
