HI ALL need some help here i captured some boxing on my aiw 7500 vcd as i was capturing my norton av popped up and caused 2 -3 % frame loss well when i was done i watched it and some parts of it chug freeze and stutter how can i fix it. please help
TAKE CARE
Vinman
Results 1 to 10 of 10
Hmm. There isn't very much you can do about the frames that went. As for sound, there might be a way to get it in sync, but generally speaking, you should have way less tha 1% dropped frames. I am almost surprised when i drop like 2 frames in a over an hour capture. As for freezing and stuff, it's hard to say... If you have access to the source material again, I'd really try recapturing.
Didja forget to go to the bottom of your right side of the task bar and shut down Nortons and anything else you don't want kickin in?
The remark wasn't smart assed lord kariya was simply pointing out the fact that if you have dropped frames, they are lost for good you can't somehow magically put them back without recapturing. What sort of answer did you expect, run it through software X and it will know what is missing and put it back for you, get real.Originally Posted by vinmam
I wasn't the one who asked for help with an impossible task, and then when told it wasn't possible decided to insult the poster who had taken the time to answer his question. When you ask questions you don't always get the answer you want to hear, and this is not the fault of the person good enough to give you a reply.Originally Posted by vinmam
oh ok my question was not answered it was a remark of sarcasm
enough said sorry i asked.
vinman
Poor capture quality. How can I fix it?
By Caprica7 in forum Capturing and VCRReplies: 3Last Post: 23rd Jul 2011, 07:50 -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11
