Results 1 to 17 of 17
  1. how to convert RM files to mpg,avi,asf or VCD?
    i wanna burn a rm videos to vcd!
    can anyone teach mi?
  2. Yes, I want to do the same thing also, can someone give us some tips?
    Jul 2002
    Look in the tools section for: Other video encoders/converters
    Program is called Tinra. It's a command line program, you can also d/l a gui in the same section. Then read some guides and experiment on how to use the program
    "The software said Win XP or better, so I Installed Linux"
  4. eo video will do it
    http://www.vcdhelp.com/rmto3.htm
    haven't used tinra,but i dont get may rm files.
  5. I have been working for quite some time on converting real media files. I have used both TINRA and EO Video. So far TINRA does nice quality files, but the audio/video is ALWAYS out of sync. I must also add that it is quite speedy in it's conversions too. It would rule if I could find a way to sync the a/v, but at this point I have had no luck. And everytime I use it I just get frustrated. You get what you pay for w/ TINRA and it's free.... Soo... As for EO Video, I found that the only way to sync the audio/video is to convert the real files to avi first and use divx 5 for video compression and divx audio for audio compression. It works like a charm 90% of the time, but I have found there are a few files that just won't come out synced. Also, it is by far way slower then TINRA and it's not free you can demo it but eventually you have to pay for it. I would try TINRA first and see if you are lucky enough to get files that are in sync when they are done. Then if you don't like the TINRA try the EO Video demo and see if it works out better. Hope this helps!
  6. Member rion's Avatar
    Thousand Islands
    my tinra never worked for me, i get the sound but no pictures, i guess it's not compatible with my old amd k6+ processor.
    but if anyone really knows the problem i have, please tell me.
    thanks
  7. i wanna no how u chge it to .wav files
  8. Member rion's Avatar
    Thousand Islands
    if you have sucessfully converted rm to avi using tinra, use virtualdub or blaze media pro to extract the audio as wav file.
    Aug 2002
    Australia
    The problem with converting Real media is always going to be the fact that RM supports variable frame rates, so in the case of some video clips it is impossible coerce it to a constant frame rate which causes the desync problem.
    For ease of use I would recommend EOVideo mainly because it can convert directly to VCD compliant MPEG.
  10. Originally Posted by oddbod77
    I see. and how would you check if your file has VBR? Is there a tool to let you know?
    =[ vinchi007 ]=
  11. Member rion's Avatar
    Thousand Islands
    yes, I have tried the program and it's okay, EO is cool not a fast encoder, but it will do
  12. BUT IS THERE A WAY I CAN CHGE RM TO .WAV FILE......???????
    universe
    real7ime comvertor will change them to avi in realtime and converts streaming rm files
    Dec 2002
    Australia
    "real7ime comvertor" what is this?
    TIA
    DJ-KeTTLe
    universe
    real7ime convertor is a software program that converts realmedia and ram files to avi in realtime wheter it is on your harddrive or streaming from the internet. all you have to do is use google to search for it. Seek and ye shall find.
    Dec 2002
    Australia
    found it thnkz
    Aug 2002
    Australia
    Please do not confuse Variable BIT rate with Variable FRAME rate as they mean very different things. The only way so far that I have been able to confirm this is by playing a clip in Realplayer then watching the framerate which is found under the "Statistics" option, you will notice that when there is no motion onscreen the framerate will drop close to zero.
    Originally I found the the problem in the TINRA documentation and confirmed it using the above method on a cartoon that had long sections with no onscreen movement.
    As far as I know (i.e. I am guessing) all Realmedia clips use variable frame rate to reduce the filesize as the work done by the compressor would be reduced considerably using this technique.
    Regards
    OddbOd
    P.S. If you have a quick computer then use a high efficiency codec (DivX, Xvid, MSMP4) to convert directly to the format you want it in, else use a high speed codec (None, HUFFYUV, DV) and make sure you have lots of diskspace. EOVideo lets you use either strategy or a "fast mode" which can successfully convert native Realmedia clips even on a slow PC, which is why I recommend it.
