I capture a lot of video from TV using PowerVCRII and convert to SVCD format using TMPGEN. Trouble is, the output file is usually too large for one CD. I have tried a number of programs to split the file, all with no success
1. DVDTOOL - cuts the file but the second file usually has no audio
2. AVI2MPG (via TMP to de-multiplex the audio/video) - again cuts the file but the second file (and I presume others) have out of sync or bad audio
3. TMPG itself - usually hangs as soon as I load the mpeg file and try to select a cut point
So at the moment I am forced to convert segments from the output from PVCRII into about 600mb chunks which is a bit tedious since it cannot be automatic
Any ideas?
Larry
I'm going to assume that you don't have the most curren vs of tmpge . In any case ry hitting the run button before you do your split/mege.
No I am running with TMG 2.53 and also have tried TMP Plus. I load the file into the merge/split screen, press RUN (no output file selected error), then try to double click the file to be split to set the times. TMPG just hangs and needs to be killed manually
Larry -
I find this method of splitting much more successful ...and faster.
Open the movie in TMPGE and then set it up as normal(templates etc)....
Then using the Source Range set start point and end point (ie:halfway point).
Go to File > Save Project..(movie-pt1)
Then go back in to TMPGE.
Go to Source Range again to set up second half of movie.
Save project again ..movie-pt2 (remember to set Output to part 1 and 2 respectively).
Then ...File > Batch Enocode > Add > Movie pt1 and movie pt2 > Run."Today is only yesterdays tomorrow" -
Forgot to mention...
So,in effect you are encoding and splitting at the same time."Today is only yesterdays tomorrow" -
Yes, What I was doing was encoding the entire movie ot TV show but the final file ended up being too big for a CD. So I had to cut it - hence the problem. But using TMPG to select the range to encode, creating a number of separate projects each processing a range of the whole movie, I can effectively end up with mpg segments each of the right size to fit on a CDR
Larry -
you can also try this: http://www.vcdhelp.com/forum/viewtopic.php?t=119181
Tried that earlier. Process works okay but the second and subsequent files either have completely out of sync sound or are unplayable. Hence the original questions
Thanks anyway
Converting DVCPRO 1440x1080 50i to 1920x1080 29.97 - Destined For Blu Ray
By videopoo in forum Video ConversionReplies: 1Last Post: 13th Oct 2009, 13:04 -
Mpeg Streamclip Problem (VOB files twitch)
By Keys in forum MacReplies: 2Last Post: 10th Aug 2009, 12:39 -
Is the Playstation 3 destined to go the way of the Sega Dreamcast?
By yoda313 in forum PollsReplies: 32Last Post: 21st Jan 2009, 17:18 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 14:34
