i need to put a couple of vcd films on to dvd, i've managed to get them to one file (mpeg format), after joining them together but can't find a way of authoring it to dvd, what am i doing wrong ?
i can't find a "how to" for std vcd to dvd anyone help please.
This won't be much help, but I have found that after I use VCDGear to switch the .DAT back to an .MPG file, and after I demux the .MPG in TMPGEnc, I get errors when trying to import the .m2v into DVD Maestro. I have to re-encode the file for VCD format in TMPGEnc before Maestro likes it. Not sure why that is. It should work without issue.
I don't know if the stream is getting a wee bit corrupted when copying from the VCD to the hard drive or when VCDGear is doing the .DAT to .MPG conversion.
So watch out for that. Haven't tried to throw it into any other authoring programs yet. -
does help a bit, do you use simple demux in TMPGEnc ?
i'll try it with spruce up then see ifthatdoes the job.
Also i used vcd cutter to convert from .dat to .mpg wether that makes a difference i don't know
demuxing .mpg in TMPGEnc no problem,
Now I get a parsing error when using SPRUCE UP to import a file, the thing is ive merged 2 vcd's, using vcd cutter and it plays ok on media player. so now whats up ?????
Just tried Maestro as well and getting same error ??
HELP!! -
maybe the best u can do is follow what nickel did.. re-encode the movie then re-author it.. i havent done it personally myself but i think that would be a wiser way to do it...
:^)I FEAR NO BEER!!! -
I have just completed my second VCD to DVD conversion. This is how I did it. Ran the movie through TMPGE to make it standard VCD mpg file. Then using DVDit SE v.2.5.2 I started a new project. Make sure on the type you change it to Mpeg1 DVD. Make your menus, load your movies, verify the size and then author the DVD and burn it. I use Nero to burn.
Thanks for that link, bugster. This stood out to me:
Note 5! This only works for VCD PAL 25 fps and VCD NTSC 29,97 fps, not VCD NTSCFilm 23,976.
This may be the problem. I think most of my VCDs from film are 23,976. So a transcoding (aka re-encoding) is necessary in that situation. DANG!
Hard drive is full right now on a home video capture to DVD-R project, so I can't test this for a week or so.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 03:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
