I encoded with TMPGE an XVID .avi
The first avi was fine, but when I did the
second half of the movie (separate .avi of course)
although it shows 59 minutes in Windows Media Player,
the video stops at 24 minutes but the audio keeps
going.
Any suggestions?
Thanks!![]()
sure pal, your prob is that your frames are freezing, its actually quite easy to fix, there are two techniques. first off is to open the video file in virtual dub. Set the video to direct stream copy and leave audio seetings alone, then goto file, and save avi. Save it to any directory, virtual dunb should fix the prob, the resulting file should be fixed. the other way is to use a program called divx-anti-freeze. It should fix the video when u play on windows media player..hope that helps, otherwise email me, shotgunanybody@hotmail.com...good luck
ops..lol...never mind dude, those two work if you were playing an avi..but u said you had converted it to a mpeg..
Ripped video stops randomly for 1 or 2 seconds
By panning in forum ffmpegX general discussionReplies: 2Last Post: 29th Oct 2011, 05:17 -
AVStoDVD stops working after encoding video
By tperkins13 in forum Authoring (DVD)Replies: 1Last Post: 19th Apr 2011, 07:10 -
Total Video Converter stops at 4GB
By texas1 in forum Video ConversionReplies: 2Last Post: 21st May 2010, 10:31 -
Video Stops Playing
By DJboutit in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 02:54 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 22:15
