  1. I am trying to fix an AVI file with VirtualDub MP3-Freeze. After removing the bad frames I select Audio, Direct Stream Copy and Video, Direct Stream Copy. File, Save AVI.
    After a while I get this error:
    AudioStreamSource error: file read error (8004406d)
    The process of saving a new AVI stops.
    Don't know what this means and how to fix it. Any suggestions?
  2. Try this:
    open .avi (make sure bad frames are gone).
    Audio > Full Processing > Audio > Conversion > Choose Rate (44100 for vcd) > Audio > Compression > No Compression > file > Save WAV.......
    This will be quite a large file (so I hope its your intention to encode it)
    then open .avi again and...
    Audio > No Audio >Video > Direct Stream > File > Save as AVI
    then open recently streamed .avi....(without audio).
    Audio > Wav Audio > Load WAV file > Video Direct Stream > File > Save As AVI.
    "Today is only yesterdays tomorrow"
  3. Originally Posted by wee haggis
    Try this:
    How can I make sure the bad frames are gone? After fixing the bad frames and trying to save the .AVI file I get the error.
    I tried this:
    1) Deleting all bad frames.
    2) Audio > Full Processing > Audio > Conversion > Choose Rate (44100 for vcd) > Audio > Compression > No Compression > file > Save WAV.......
    This results in a .WAV file of 0 bytes.
    Then I tried this:
    2) Audio > Direct Stream Copy > Audio > Conversion > Choose Rate (44100 for vcd) > Audio > Compression > No Compression > file > Save WAV.......
    This produces the same error: AudioStreamSource error: file read error (8004406d)
  4. When you open it in Virtualdub...what does the File Information say under Audio? (ie:AC3/MP3..etc,etc)
    How about just opening the file,audio Direct Stream and save as WAV?
  5. Originally Posted by wee haggis
    Audio Info:
    Sample Rate: 48000Hz
    Channels: 2 Stereo
    Sample Precision: 0-bit
    Compression: MPEG Layer-3 Codec (professional)
    Preload skew:
    # frames: 303046
    Direct stream audio produces same error.
    But I don't give up that easy!
    Thanx for your help so far wee, really appreciate it.
