My standalone DVD player is not being able to fast forward /rewind SVCD i create with TMPGEnc using the SuperVideoCD (NTSC).mcf template. The only thing i changed was set the encoding to 2pass VBR 1750kbit/sec and non-interlaced.
I read a solution here of Demultiplexing with TMPGEnc and Multiplexing with BBmpeg.
Here's the problem:
demultiplexing with TMMGEnc 12i gives me a video file test.m1v and an audio file test.mp2.
Multiplexing with AVI2MPG2(bbmpeg) i can add the video file. But it doesn't see the test.mp2 file. I change it to all files and load the test.mp2. Then i get an error "could not get time per frame from the idirectdrawstream".
Anyone know what i'm doing wrong?
This may once again have to do with the fact that TMPGEnc generates scan offsets that conform to the Chinese SVCD spec rather than than the US/Phillips spec (or so I was told anyway). The simplest way may just be to build a disc image using VCDImager with the "update-scan-offsets" option enabled. Might save you the trouble of remuxing through bbMPEG.
Multiplexing Multiplex files?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 4th Dec 2012, 00:54 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 23rd Apr 2011, 00:59 -
Multiplexing Issues (mp4muxer 0.9.3)
By JuddM in forum Video ConversionReplies: 4Last Post: 19th Jan 2011, 06:00 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 16:52 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 06:45
