  1. Hi! I have recently converted some RM files(Kenshin) to MPEG using EO Video. It converts the file fine, but the video is corrupted for the last 4-5 mins. It states unexpected video stream during the process of conversion in EO Video. The new .mpeg file gets stuck at one frame, while the sound plays normal. So, i tried converting the RM to AVI first using Tinra, and it converts it fine, but when i try to convert that AVI file to a MPEG using TMPGEnc, it says the AVI file cant open or might be corrupted. I tried several RM files, and the same results is what i get. Any suggestions?
  2. Use Virtualdub to check for Bad Frames
    "Today is only yesterdays tomorrow"
