recently downloaded a movie with these files: image.cue, image.toc and
image.bin...
when i opened the .cue file with daemon-tools it worked good as always but, there wasnt any folders in there as there usually is, except the .dat file.. i have had no problems with them .dat-files before, but this one wont open in no media-player what so ever, tried many of them, even tried to convert the dat file without any luck..
there did come some support files with the movie, also tried them without any luck, here is what they are called, dont know exactly what they are for but you guys might spread some light on this question...
the file names as they came:
dat_assoc.zip
mode2cdmaker-142.zip
mode2cdmakergui10.zip
riff-cdxa-filter-test6b.zip
if you know what they are for, or even know how to play the .dat file plz answer
Thanks for any help
frozenQ
i guess the meaning of the DAT was a VCD or an SVCD... Try renaming your file to a ****.MPG...
(Had the same prob as u have, and that fixed it
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 21:29 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 22:38 -
Anyway to fix a .dat?
By demonwarrior in forum EditingReplies: 2Last Post: 19th Jun 2007, 05:30 -
LG DAT-200
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th May 2007, 11:26
