downloaded a few subtitles for amovie but, the problem is that none of them matched the movie... what i mean is that the lines didnt come in the same order as the voices on the movie,
now the q is, is there any easier way to edit the subtitles then doing it manually? like some prog or something? would take a long time doing it manually....
Thanks for any help
frozenQ
Most of the subtitles are regular text files... open them with notepad...
but, if you say the movies aren't in syncro, that means that the subtitle file has another frame rate as the movie... There are some gr8 proggies on this site to fix that...(check in the AUTHER part of this site.. you'll find some tutorials there)Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
thanks for the reply.. mind telling me what proggy is good for it?
tia
frozenQ -
If your subtitle-file is in srt, this is a good way to resync:
http://www.vcdhelp.com/forum/viewtopic.php?t=114509&highlight=
I wrote the guide myself and I've been doing it like that for some time now. Works everytime for me.
J
Adding/editing subtitles with .ts material (BluRay-rip)??
By Totaldental in forum SubtitleReplies: 4Last Post: 7th Sep 2014, 07:36 -
menu editing and audio/subtitles?
By asiafan in forum Authoring (Blu-ray)Replies: 0Last Post: 26th Feb 2011, 11:37 -
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 19:43 -
Editing Integrated/Embedded Subtitles
By Ofelas in forum SubtitleReplies: 3Last Post: 28th Jan 2010, 16:12 -
Editing subtitles in .avi file
By telecomguy9 in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2007, 13:15
