hello all,
i'd like to know your opinion about the best dvd burning app if possible
i have nero and when i burn, i cant play content on DVD Player in TV, but nero dont gives me error in burning
any other good program outthere?
thx
hi there
your problem isnt nero or burning process it might be cause your dvd player is region locked
goto
http://www.vcdhelp.com/dvdplayershack and look for your model and brand of your dvd player and find the code to change the region to 0 as it will then play any dvd in the world. The world is split up to 9 different regions to play dvd -
It may be that your DVD player isn't capable of playing VCDs, SCVDs or burned DVDs. Check the player compatability list on this site to see.
hello,
thx for the answers, my fault that i forgot to tell me system, i have mustek v560 unlocked, the problem is that i put a dvd authored with ifoedit on mustek = gives data error on TV screen, i put the same dvd on WInDVD = crash WinDVD, i copy VIDEO_TS to root of drive = gives error "File nš1 is invalid" / File nš1 = 1st vob of the set,
thats why i ask if isnt nero corrupting my burning somehow, i readed on some forums about do some bitsetter before burning, dont knwo if this is gonna help or not.
btw, my media is from brand PLATINUM
any idea?
P.s: after i author i open with media player and ifoedit player and it plays nice.
thx -
any idea pleaze, sorry for bugging all of you, but i am in that point of no ideas
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 02:25 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 04:28 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 20:21
