Hi all, I'm trying to backup "Murder By Numbers" I first ripped with DVDDecryptor, demuxed .AC3 and .D2V with DVD2AVI, compressed video with TMGP, compiled DVD with Maestro.
When I played the DVD, the audio is a few seconds faster than the video.![]()
It's like this, in the first few seconds, the "WB" logo shows, I think the audio is correct. Then the "This Motion Picture Is Rated R" screen comes up. There is no audio on the original DVD, but on my backed up version, the audio of the second "WB" screen starts to play. And when the second "WB" screen shows up, the audio the "Castle Rock Entertainment" (the light house screen) starts to play...
I don't have this problem with any other DVDs. Any suggestion would be much appreciated! Thanks very much in advance.
kothreat@yahoo.com
This is exactly the same problem as I had with 'Ice Age'.
See
http://www.vcdhelp.com/forum/viewtopic.php?t=110032&highlight=
"Found an easy solution - DVD2AVI allows the user to set the start & end points (rather like the MPEG tools of TMPGenc). Simply by setting the start point, using the slider, after the 2nd intro, I can get near perfect AV sync (as close as TMPGenc allows). "
PN
Audio out of sync, how to determine delay needed.
By mattstan in forum Authoring (DVD)Replies: 9Last Post: 23rd Dec 2019, 02:26 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Video scattering , audio sync variable delay in MKV files
By prabhakarlad in forum Software PlayingReplies: 13Last Post: 22nd Apr 2011, 14:55 -
Audio with delay making the proper sync
By ranosb in forum AudioReplies: 1Last Post: 25th Jul 2009, 21:09 -
Audio Delay and other potential A/V sync Issues?
By rkr1958 in forum AudioReplies: 1Last Post: 2nd Dec 2007, 14:33
