hello all,
i have an HP dvd+r 200i and i was using some media from PLATINUM brand, i started to have problems when play burned media in my mustek v560 TV Player.
i am asking if anyon eout there have the same problem, i found this on forums
"Ricoh DVD+R showed problems: remuxxing using ReMPEG with Bitrate limited to 7500MB improved the results when running using PLATINUM Brand DVD+r.
Plays DVD+RW. Must set the compatibility setting to mode 2, otherwise it says "NO CD". Read : http://www.dvdplusrw.org/resources/bitsettings.html"
i have to do the bitsetter thing everythime i burn a dvd? or can i flash my hp fw and my problem is solved?
thx in advance,
cheers
Results 1 to 1 of 1
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 03:03 -
Compatibility of burned DVDs
By cool612 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2010, 22:16 -
LG LDA-830 media compatibility
By Magritte in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jan 2008, 21:51 -
How do you store your burned media?
By surfmonkee in forum MediaReplies: 10Last Post: 10th Jan 2008, 11:38 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 18:07
