I'm referring to the article on the main SVCD page, where you fool the player into thinking its playing a VCD, when its really an SVCD. I have a few questions:
1) Does this work for all players? I just got an Akai ADV 2280 player, which supports VCD but not SVCD. Didn't realise until it was too late... Will the trick work for this player?
2) Does it work with CVD as well?
3) If using this method, can you still use all the things SVCD can support that VCD can not?
1) No, unless it is mentioned in the DVD players report on this site you won't know if it will work unless you try it.Originally Posted by legionpc
2) Don't know, again try it. Would be interested to hear your findings.
3) I wouldn't expect so if SVCD is not supported the SVCD only features will not be supported.
incompatible recording between DVD recorders?
By hillneerg in forum DVD & Blu-ray RecordersReplies: 11Last Post: 7th May 2010, 12:23 -
Are DVD-R/DL (double layer MINUS R) incompatible with ISO/MDS for +R/DL?
By miamicanes in forum DVD RippingReplies: 16Last Post: 31st Dec 2009, 22:24 -
Recommendations for dvd-to-zune software? -Corel dvd copy does the trick!
By yoda313 in forum Portable VideoReplies: 7Last Post: 17th Sep 2008, 01:13 -
DVD Fab incompatible with DVD Shrink
By JohnnyBob in forum DVD RippingReplies: 14Last Post: 14th Sep 2008, 20:59 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 20:07
