I've spoken with ATi about using a North American AiW Radeon to capture from PAL analogue source.
They said this is supported but analoge playback as PAL is not.
IF that is true (haven't tested with hardware yet), are there any "gotchas" to be aware of? Capture would be by VirtualDub using HUFFYUV or MainConcept DV codec.
Also, would someone please direct me how to make a cable which would have the PAL (SCART?) on one end for use plugging into the VCR and composite (or, prefereably, S-video) on the other? I'll probably start with some kind of PAL extension cord to get the connetor on a cable set and need to add an S-video or RCA connectors.
Are any of the commonly available (say...il Gigante in Italy) PAL VCRs equipped with stabilization and noise reduction?
OK, forget the idea of an adapter cable. JVC makes a VCR model HR-J481M$ that sells online for about $150 that will do PAL, NTSC, and SECAM with composite RCA jacks for output. That's not as nice as S-Video but the price/convenience is very good.
OK, that leaves the aspect of doing the capture of PAL source played into an AiW Radeon for capture with VirtulaDub.
Has anyone done this? What tips will you share?
Capturing unknow PAL VHS source. Can be watch on TV but not recorded on PC.
By Bellower in forum Capturing and VCRReplies: 13Last Post: 28th Dec 2011, 18:16 -
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 12:20 -
Hauppauge PVR-150 (PAL Version) Recording NTSC Source: Impossible?
By darkarn in forum Capturing and VCRReplies: 53Last Post: 16th Aug 2010, 10:06 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 13:16 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 13:15
