Hello- I have a Chaintech Mobo and want to upgrade my Ati Rage 3D IIC video card for one that allows the use of dual monitors. The AGP Slot is a Version 1 with 67MHz bus speed, a Max Data Transfer Rate of 2X, and an Aperture Size of 64MB (At least, that's what SiSoft Sandra says). I don't want to spend money on a card that is beyond the capabilities of the AGP Bus, but I am interested in spending enough in order to get the most out of what I do have. Since I am completely new to video card tech, I'm hoping someone will be kind enough to suggest a dual monitor video card that would be best for my system.
Thanking you in advance, Wendell Novotny
wendellnovotny@netscape.net
You can give a look to the ATI Radeon 7000 VE... There's lots of others out there, but anyways, it does the job, supports AGP up to 4x, and it's quite inexpensive nowaways...
HELP: advice external video monitor options for color correcting
By DvdRookie in forum EditingReplies: 3Last Post: 14th Mar 2011, 15:20 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 00:58 -
Multiple DV source Capture card/box help/advice needed please
By OdubruS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Dec 2007, 11:08 -
a question about dual monitor video cards
By wingnut2003 in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 07:49
