I have a divx movie that I extracted the audio from. Thw wav file when played is crystal clear, but after converting the svcd the sound has alot of noise or crackling in it. I already have the toolame program being used as my external decoder for the audio, but I cant seem to fix this problem. It seems that every Svcd that I encode has a Hiss in the sound that wasnt there prior to encoding. Any sugestions?
When you save out the wav with Virtualdub try letting it do the resampling, and make sure *High quality* is ticked.
I never have any audio problems using this method. -
The wav file is not the problem. When I play the wav the sound is excellent, its only when I encode the svcd that the audio of the file has got alot of noise in it. I have even tried demuxing the audio and video to clean it up but when I do that the audio is again nice and clear. Could there be a problem with the player I am using maybe? I use PowerDVD 4.0 XP.
On a sepperate note when I play a svcd file in this program it strechs the movie to full screen when I know it should be wide screen. I cant find any option to change this. How do I? -
I know the wav is not the problem. I suspect the resampling rather than the encoding is the problem. Why not try what I suggested, and see if you still experience the same problem?
I have extracted the audio using virtualdubb using 44100hz high quality but it makes no difference in the mpg. The sound still has an audible hiss in it.
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 11:03 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 14:46 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 00:53
