Hi, anyone recommend a good codec and method to fit 2, 700k kb avi files to one 650mb disc? I've had fair luck with xvid and low-motion divx. Reducing data rate to below 600kps. (using virtualdub) Should I try messing with the frame rate? Would that screw-up the audio sinc? info appreciated!
makes a total of 1.4mbs of data
i dont know how you cannot fit this on a cd in either vcd/svcd standard.
micGod created man and finding him not sufficiently alone, gave him a companion to make him feel his solitude more keenly. -- P. Valery -
Please give us some more information.How long are your avi's?:What resolution?The size of your avi file is not important,but how long is the playing time.
How to Compress Four to Five movies onto One DVD-R 4.38gb blank disc ?
By 351shaker in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2011, 06:10 -
what is the video codec which compress and keep the most quality part ?
By Michael REMY in forum Video ConversionReplies: 3Last Post: 28th Aug 2010, 09:03 -
1,5 miniDV (20gb) to DVD disc (4,7gb) compress
By etnies in forum Video ConversionReplies: 1Last Post: 19th Nov 2009, 10:34 -
play DV-Codec AVI-video on a multimedia external disc on TV
By sigmaflex in forum Media Center PC / MediaCentersReplies: 3Last Post: 13th Dec 2008, 08:54 -
By sigmaflex in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Dec 2008, 14:19
