I have all-in-wonder rage 128 card. It has also tv-turner inside. However, I could never get it to work. I finally used the latest software and drivers and it worked fine, only one problem : NO SOUND.
ANyway, I'll reinstall my OS and see if it fixes the problem.
Well, the question I want to ask is - I would want to get a PCI capture card to record some cable shows. I think I'll use the svcd or divx format for that conversion, but I would want to know what card should I buy - I want it to have good quality and be as cheap as possible. not more then $50
Please advise which card I should get.
Big thanx for any advice.
=[ vinchi007 ]=
As long as you have the AIW audio-out cable plugged into the line-in on your sound card and have selected Line In as the recording port through the Windows volume control you should have no problems with the sound. Also try to get your hands on version 7.6 of the ATI MMC software. If I can help please email me as I have an AIW 128 running on Windows 2K and am having few if any problems
Thanx for any help. I got it finaly working. I'll start learning how to capture correctly now
=[ vinchi007 ]=
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
