Can anyone else out there who has the Pioneer DVR-105 dvd recorder, tell me if they are able to burn any .bin, .cue images? I am getting the following from Alcohol 120% 1.3.5 Build 1125
I have also tried using Nero 5.5.9.17, Fireburner, and CDRwin 3.9b with almost identical results, and can provide logs for each programs results if anyone wants to see them.
===------------=== Source Disc/Image Information ===----------------===
Type : CDRWIN Image file
Path : D:\Download\Movies\To Burn\MyMovie
MyMovie.bin
Session: 1
Track: 2
Session 01 :
Track 01 : Mode 2 Form 1, Length : 000534(1.0 MB), Address : 000000
Track 02 : Mode 2 Form 2, Length : 331644(647.7 MB), Address : 000684
===------------=== Recording Progress Detail Log ===----------------===
PM 07:20:37 Processer info : Intel® Pentium® 4 CPU 1700MHz (1707MHz)
PM 07:20:37 Memory Buffer using size: 128 MB
PM 07:20:38 Image file loading : D:\Download\Movies\To Burn\MyMovie\MyMovie.cue
PM 07:20:38 Source Info : Session : 1, Track : 2, Length : 649.1 MB / 073:51:03
PM 07:20:38 (IPIONEER DVD-RW DVR-105 (0:0) : Recording Method/Speed
PM 07:20:38 Recording - DAO / SAO - 16X (2400 KB/Sec)
PM 07:20:38 (IPIONEER DVD-RW DVR-105 (0:0) : BURN-Free activated
PM 07:20:38 (IPIONEER DVD-RW DVR-105 (0:0) : [SEND CUE SHEET ERROR]
CDB : 5D 00 00 00 00 00 00 00 30 00 00 00
D:-0--1--2--3--4--5--6--7--8--9--A--B--C--D--E--F--
41 00 00 24 00 00 00 00 41 01 00 20 00 00 00 00
41 01 01 20 00 00 02 00 41 02 00 20 00 00 09 09
41 02 01 20 00 00 0B 09 41 AA 01 24 00 49 35 03
S:KEY - 05/26/00 - "Invalid Field In Parameter List"
PM 07:20:38 (IPIONEER DVD-RW DVR-105 (0:0) : Recording failed!
PM 07:20:38 Error message : [05/26/00] - Invalid Field In Parameter List
PM 07:20:38 Image file loading aborted!
PM 07:20:40 Something is wrong with the recording procedure!
Please check the log file and report any errors to Technical Support.
TIA for any pointers or help, but I hope Im not correct in thinking I may be waiting for a Firmware upgrade....
Doug
Results 1 to 13 of 13
i am using the 105 and have no problems burning bin/cue files as long as i use nero. Just select burn image takes about 10 seconds before it starts to burn though, but hasnt failed me yet.
I have found that this problem was common of the A03, and A04 units, and was fixed through firmware
I have also learned that people with some sony drives are experiencing the same identical issue...
I wish someone could shed some light on this...
Doug -
No probs burning .IMG files to full capacity. Have used latest Nero, DVD Decyypter (in burn mode) etc with no issues at all. Used IFOEdit and IMGTools to create the images. Nero in it's 'DVD Video' native mode is not good for compatibility - this works in one DVD player but not another - IMG files from IFOEdit work in every single player I have tested.
"PM 07:20:38 Recording - DAO / SAO - 16X (2400 KB/Sec)" - I wouldn't be too confident on this line - I assume you are burning at 2x - have you tried at 1x - it could be your media ?
I'll try some BIN/CUE files tonight with Nero and update this post .. -
Sorry - just realized that I assume you are burning CDR's and not DVDR's ... Doh...
I haven't even tried CDR's yet on my A05 - I'll try them tonight .... -
jmbuis, and TeeeRex
if you can burn cdr's can you tell me did you have to reinstall your cd burning programs after removing the old drive and installing this one? and also can you tell me if your firmware is version 1.00?
I have not re-installed my programs, and my firmware IS 1.00 for the DVR-105
Doug
still suffering along here... -
I didn't flash the drive's firmware but I installed nero after installing the drive because the previous version didn't support it
kingfenix,
Didn't have to reinstall Nero because it was the latest anyway. Have burnt CD's fine with the A05 and yes its FW v1.0
All my A05 troubles seem to be over - I blame them all on crud media and Nero (for DVD burns).
Cheers,
TeeeRex. -
which brand of media was crud? and which do you use now that made your problems go away?
Doug -
well I bought 20 Zero Defex CDR's that cdr-media.co.uk were raving about - the burner forces them to 2x (you cannot write to them at 1x) - they are rated 2x but are always coasters.
All the 1x Media I've tried works fine - Traxdata, Datawrite, even BulkPaq works OK - though after 1 hr there was a few breakups in DVD video. (theerfore not recommended). Also tried the latest white label (which is actually light blue?!) and ice white - all with no problems. (all at 1x mind you).
Stick with datawrite/datasafe - they are cheap enough now and should proove reliable in most DVD players etc.
CDR's are not a problem - 12p disks work fine in anything !
Hope this helps. -
bin/cue writing problems to CDR
Drive Cendyne DVR-105
Failure with latest versions of Nero Burning ROM
and CDRWIN 3.9B
Successful bin/cue write in Nero after changing
write option to Track At Once.
Failure for both DAO and DAO/96 options -
DAO for bin/cue write on CDR works with Nero after updating ASPI drivers from nero site.
bin/cue write OK with DAO mode or TAO
DAO/96 still is not OK.
Pioneer DVR-520H video to PC using the DV-Out port - no disc burning.
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th May 2021, 15:26 -
My Pioneer DVR-531H-s has developed burning problems ... replace burner?
By FulciLives in forum DVD & Blu-ray RecordersReplies: 86Last Post: 9th Dec 2009, 18:09 -
Pioneer DVR-560HX & random problems with CAM module + video adjust menu
By vincent_scot in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Mar 2009, 12:03 -
DVD-burning problems (Pioneer DVR-630H)
By tigrr in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jan 2008, 11:24 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
