Frst of all, I will admit to never having used CCE on its own. I have used it through dvd2svcd, and must say that the mpeg2 output was much better than svcd's made with tmpeg at higher bitrates! With that said, I want to use CCE to make dvd files to put on dvd-r's. I was wondering if anyone could point me in the direction of a good giude to use for CCE, and if there are any templates that CCE uses to make dvd's(like tmpeg). Any info will do. I want to learn how to use it, but its not as simple and forward as tmpeg was when I started that. Thanks in advance
Have you downloaded the manual from their web site? If not, that should be your first step...
BeTa -
AnonymousGuest
There is no templates in CCE, you have to do all the work . There is no resizing available either.
But CCE is fast with the best MPEG2 quality available.
Thats why we use it.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 21:14 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
Looking for an MPEG-2 Encoder like CCE and FFMPeg Questions
By Maikeru-sama in forum Video ConversionReplies: 85Last Post: 1st Sep 2008, 00:24 -
Questions about CCE, H264 and AviSynth
By Maikeru-sama in forum Video ConversionReplies: 18Last Post: 21st Dec 2007, 21:38
