Hi, I have literally just installed my new sony dru500a dvd writer,
I ripped my copy of spiderman using smartripper, then used
IFOEdit........
I have these files in a dir:
VIDEO_TS.IFO
VTS_01_0.IFO
VIDEO_TS.BUP
VTS_01_0.BUP
AND 5 VOB Files.
How do I burn these to disc so that it will play in my dvd player?
Do I add the IFO file to a program? If so which IFO and which Program?
Nero can't *see* IFO's only ISO's?
Is there a program I can use to burn these files?
Please help me
are all those files under 4.7 gigs? if so nero can burn them. i have heard spiderman is under 4.7 gigs if all the extras are removed.
yes it is under 4.7 gigs, but how do I burn in NERO?
Do i add the VIDEO_TS file,
in IFOEdit, when I try to create the img file, It asks me
to select a source drive (which one?) I have tried
different one, but I keep getting an imglib.dll error
Can you help me solve this? -
First you need to make new ifo files with ifoedit. Use the vob files with the main movie to do this. Then open NERO and drag the two ifo files, two bup files and the vob files to the VIDEO_TS folder in NERO. Finally, burn on a RW media first to test and later to the R media. If you are not successful with NERO then use PRASSI.
The above mentioned procedure will produce a copy without menu and other junk...just the movie.
Virtual DVD writer?
By Nick Burns in forum Video ConversionReplies: 4Last Post: 31st Dec 2010, 10:18 -
dvd writer help
By Stephb in forum DVD RippingReplies: 2Last Post: 2nd Feb 2009, 16:38 -
dvd / cd writer
By bill gailer in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jan 2009, 22:18 -
After a new DVD Writer..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 11:01 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 01:08
