I'm trying to convert a NTSC SVCD to PAL format.
I've de-multiplexed the file using TMPG. I tried converting the video with ReStream and the audio with Cooledit pro (saved as an mp3).
However when I try to multiplex the new video and audio files, I get the following message:
11s packets cause buffer underflow.
The MPEG file might cause error when it played.
Am I doing something wrong, or does someone know a better way to convert from an SVCD from NTSC to PAL?
Results 1 to 11 of 11
I would suggest you try burning and playing it. I get this kind of error all the time when using the 'vcd header trick' to get SVCD's to play on my VCD player and they are fine.
I have to ask though are you sure you need to do this conversion? AFAIK, all PAL DVD players will play NTSC disks. They will output either NTSC or PAL-60 and chances are your TV will handle this. If you haven't already I would check your TV/DVD player capabilities for NTSC playback, you may be pleasantly surprised! -
1) Yes, I've burned it, but there's no sound when played pack on my DVD player
2) My DVD player/TV can play NTSC, but not very well. Video plackback is generally quite smooth, but I get a with widescreen films I get a flickering effect at the top and bottom of the film. -
You could try re-emultiplexing with BBmpeg. I don't use it myself but some people on this board swear by it for this kind of thing.
EDIT
BTW, never heard of restream, it it some re-encoder or what? -
Originally Posted by bugster
restream just changes the frame rate in MPEG headers. -
Do you really need to convert ? Why don't you try it in your DVD player first, and see ?
I have a pioneer DV330 that play both PAL and NTSC VCDs, with only a few missing lines at top and bottom, that anyone can hardly tell. -
Originally Posted by Spaceboy
And make sure when you save your wav it is resampled to 44.1kHz if it is not already! -
yes I remultiplexed the video with an mp3.
As restream simply changes the framerate info in the header, it will actually playback the video slightly faster. I think therefore you will have to change the length of the audio while in cooledit if you want to maintain audio/video sync. Open your changed video file in WMP and note the length displayed. Use this to shrink the audio (I assume cooledit can do this). Then save as a 44.1khz .wav and convert to mp2 as banjazzer suggested. Then re-multiplex the video with your mp2 file and you should be ok. -
Originally Posted by banjazzer
b) How do I convert the downsampled wav to mp2 with TMPGEnc?
Thanks. -
b) How do I convert the downsampled wav to mp2 with TMPGEnc? -
Thanks. I still get the "11s packets cause buffer underflow." message with TMPGEnc with multiplexing, but it playbacks fine on my DVD player now
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 13:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 09:06 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 11:46 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
