Hi.
Is there other editing software similar to VirtualDub that have something like "Direct Stream Copy" for both video and audio? Please and thank you. Does Adobe primer do that? Please and thank you.
it might be easier to help if we knew what you were trying to do/more details
Hi.
I have this .avi that I want to burn to a cd, however, it is just a tiny bit to big. I thought maybe I could cut a little bit of the movie out, so it would fit on 1 cd, however, when I tried to take some off with virtualdub it gives me a VBR audio encoding error. When I get that error, if I do not save the wav file then add the wav that I saved, the voices are off, however, if I save the .avi with the wav I added, it makes the .avi a lot bigger even in "Direct Stream Copy" for both audio and video.
So, I was wondering if there was different burning software that will make the file smaller and not bigger with the different settings maybe like with what virtualdub gots or is there a way to fix virtualdub with the vbr error to where it will make smaller instead? Please and thank you.
I apologize for not being very clear before. -
you can cut out the end credits(and beggining if you wish) to make it fit on 1cd. virtual dub is a great editor,you just have to learn how to use it.
first off you now have to get a different kind of virtual dub. better yet, read this.....it should help you out.
http://www.vcdhelp.com/virtualdubedit.htm -
Nandub will deal better with vbr audio, and will also let you cut to the nearest keyframe at a chosen filesize.
Thank you for all the help. I really appreciate. They work great and just what I wanted. Thanks once again for all the help.
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 22:09 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 08:17 -
The VOB equivalent of "Direct stream copy" in Virtualdub
By l-w-c in forum EditingReplies: 30Last Post: 21st Oct 2009, 15:13 -
Premiere Pro "direct stream copy"?
By Colmino in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 11:31 -
Virtualdub direct stream copy takes _forever_. What's going on?
By Colmino in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2008, 09:01
