Hi I've been trying to make a mpeg1 based dvd to put the first season of smallville on which i downloaded I've converted the file to this format MPEG-1 Video 29.970 fps 352x240 1150kbps and converted the audio to MPEG-1 Layer II audio at 48000 16 Bit Stereo. I've tried a lot of different programs to try and make a dvd compliant vcd-dvd but all of them want to re encode or do something different can someone tell me how I can make this vcd-dvd with Ulead DVD Workshop? Does it need to convert the video to mpeg2 and at the end when it says make disc do I need to make a custom template with the same settings as my video/audio mentioned above?? When I do this it says MPEG Audio is not a standard audio type for NTSC DVD. I'm really struggling to make this and i've been playing around with this for a week!
TIA
Tristian
I just finished a DVD-R with two mpeg1 movies that I converted the sound to 48k but, I authored with Sonic DVDit SE. The movies were each about an hour long and after authorizing the DVD was just over 3gig. DVDit did some conversion on the sound and video. After it was done(took a long time) I used Nero to burn.
Sorry I don't know about Ulead DVD WS in this respect but Dazzle DVD complete will do what you want and not -re-encode anything.
Originally Posted by Tristian
I have just put the whole first season of friends (encoded with TMPGEnc) onto 1 XVCD-DVD disc
I've managed to do it now the problem I had was I needed to register to get the latest update to 1.3 and the "do not re encode" option appeared it takes a long time still up to 2 hours but that's better than the 6 or 7 hours it was taking in the end i did this :
downloaded the smallville episodes converted the audio to 48000 put them into ulead dvd workshop put the mpegs onto to a menu at the end i created a custom profile with the settings of VCD ie : frame size 352x240, constant bitrate of 1150 Audio set to mpeg audio, stereo, 48000, 224. and then hit make disc it said mpeg audio was not meant for dvd's blah blah and i just choose continue a little while later I have 10 episodes of smallville on a dvd that works in my standalone! -
Originally Posted by austin316gb
If you need any help that this thread doesn't cover let me know. -
Originally Posted by Craig Tucker
Thanks in advance.Cecilio
Suggestion needed from DVD to HD
By onlygk in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2010, 05:44 -
Dvd hacks needed
By poisonivy4 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jun 2010, 10:38 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 22:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
