On my PC, when you go onto AOL and then goto VCDHelp it doesn't automatically log you in from last time and then after you login, if you click on another page it logs you out.
Now on IE when you go on it, you have to login and you cna do everything but, it doesn't automatically log you in next time.
It's getting to be a pain in the you know what but...
Any suggestions?
My cookie settings are at low. And anyways I have VCDHELP on the list to always allow cookies...hmmmm
anyone else with same problems? I did change some settings to fix some aol problems (tips from www.phpbb.com ).
Ok, I tired everything on AOL and IE again.
IE has the same problem as before, just doesn't log you in the next time.
AOL has gotten better because it doesn't log out when you click on another page. It does the samething IE does. The next time you come you must log in again.
Linux Login
By Nelson37 in forum LinuxReplies: 16Last Post: 9th Jan 2011, 09:52 -
login as administrator W7?
By neworldman in forum ComputerReplies: 1Last Post: 18th Mar 2010, 10:30 -
Computer login question
By rubberman in forum ComputerReplies: 28Last Post: 17th Aug 2009, 11:01 -
XP login screen
By rubberman in forum ComputerReplies: 6Last Post: 10th Aug 2008, 11:00 -
login not keeping password....
By rubberman in forum ComputerReplies: 3Last Post: 25th Jul 2008, 14:13
