I am using iuVCR to capture using the Aver EZ DVD Maker card as it works well in 98 with a 4GB workround. I can capture to 720 by 640 with no dropped frames from vhs. However when I try to use VDub to join the avi (huffuv codec) 4Gb portions Vdub gives the error either "cannot append segments. The video streams have different sampling rates (24.99731 v 24.99844)" or "cannot append segment. The audio streams have different sampling rates ( 44091.0000 v 4400.5000)" depending wether the audio or video is chosen as the master stream in iuVCR.
What can I do? Mail is returned from the iuLAB support.
Problem resolved.
Untick Master Stream (in Options) as this facility alters the audio or video frame rate to try and keep them in sync.
I can now capture at 768 by 576 with the preview window disabled and no dropped frames in iuVCR.
Also can now use VDub for things other than capture.
Hope this is of use to someone else.
problem with Srestore (or something) script in Vdub
By spiritgumm in forum Video ConversionReplies: 9Last Post: 21st Apr 2011, 19:32 -
VDub + TextSub + multipass problem
By Keeyu in forum SubtitleReplies: 3Last Post: 14th Jan 2011, 10:11 -
VDub Problem
By heygurl in forum SubtitleReplies: 8Last Post: 9th Dec 2010, 19:38 -
vdub avi file opening problem
By naveenkrish in forum EditingReplies: 3Last Post: 8th Jun 2010, 12:54 -
Vdub problem
By RR420 in forum Capturing and VCRReplies: 0Last Post: 8th Mar 2008, 14:43
