  1. Hello you guys and girls,
    I tried to convert form Mpeg4 (DivX) to Mpeg2 (SVCD). Tools: Tmpgenc and Virtual dub. Settings: Bitrate:2000; Motion Search Precision: High quality (slow); Video arrange method: Full screen (keep aspect ratio). Burned with Nero. But when I'm playing it on my dvdplayer or the one of my friend or even on powerdvd on my pc, every 2-3 seconds it stutters if you know what I mean. I can play SVCD converted from a real dvd. So it has to be my settings or the tool I think. Anyone clever enough to help. Thx 2 u all!
  2. Have you ensured that the framerate of your final mpeg is the same as that of the original avi? If not then the framerate conversion done by TmpGenc would cause some stuttering.
  3. Thx for the reply. Well the original framrate of the DivX is 23,976 so I retried it but then I noticed that the frameratie in Tmpgenc is fix on 25? Can I fix this in some way?
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If U cancel the wizard in TMPGEnc (or use the "unlock" template), you can set the frame rate on the Video tab under Settings. If you set this to 23.976 too, the stutter ought to vanish.
    /Mats
  5. Originally Posted by FunkyDolphin
    You need to load the NTSC film template. If you are in PAL country there is still a pretty good chance your TV/DVD player will handle it. If not there is a guide soemwhere on this site for NTSC to PAL conversion or I can give you some help on that if required tho its a bit of a hassle.
  6. thx for the information. I did set the frame rate the same as the original but on my dvdplayer he's still stuttering. And what template do I need to use (I'm using TMPGEnc 2.58), because there are a lot of them.
