I am trying to rip a DVD to SVCD, I looked it up in this website, it seems like the I need to buy some software before I can do that, is that true? Is there anyway I can do the conversion without for free? If there is, please tell me what kind of software I need to dl.
it's all there you know. youll need a ripper. use smart ripper, there's a guide. youll need an avi convertor. use dvd2avi, there's a guide. youll need an encoder. use tmpgenc, theres a guide. youll need burning software, use nero, theres a guide. use cd-rw's. you're going to make mistakes, and learn from them.
Humm... Only Nero is one you will have to buy... Though many CD-Rs come with Nero, Adaptec or NTI.. Any of which can burn some nice VCDs!
Nero : Great all around proggie, but VCD menu kina sux
Adaptec :Advanced menu features for VCD, smokes Nero in that area
NTI : Nifty, but only use the NEWEST version, older versions will fart your OS!
Good luck!
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Should I Get An HD Camcorder? (Newbie)
By davebo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 21st Jan 2011, 03:48 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
