Hi,
Can you please give me a step by step guide on how to split a movie into 2 DVD-Rs using Ifoedit 0.94
I have gone as far as decrypting the movie to my hard drive but from there I even tried to split the movie using the Ifoedit ver .94 and have gotten the movie splitted into the 2 folders but when I burn the movie into the DVD-R using Nero, the movie doesn't play on my stand alone DVD player.
I don't want to process/reencode the audio or video, I want to keep the same quality of the original movie even if I have to use 2 DVD-Rs.
Thank you.![]()
Bump!
Is it something like this?
Using Ifoedit 0.95
1- Open Ifoedit 0.95
2- Click Open on the left bottom of the screen
3- Browse to where the movie has been decrypted
4- Click the VTS_12_0.IFO file of the movie
5- When the movie directory opens in Ifoedit, click VOB Extras
6- Click Split to 2 DVD-Rs
7- Create the 2 folders where Disk 1 and Disk 2 will go
8- After Ifoedit finishes, Open within Ifoedit the VTS_12_0.IFO file of each folder and click Get VTS Sectors
9- Try to play the movie with PowerDVD, if it works burn it with Nero
***Important***
When ready to burn make sure that all movie files are in a folder named VIDEO_TS (Notice that all are CAPS)
Nero creates the VIDEO_TS folder for you. All you have to do is drag the files to this folder in Nero.
Please confirm. Thank you. -
This Nero, is this the regular Nero you download from the site or is it a differnet version for DVD-R burners? I have full retail copy, I just want to make sure.
HideOut -
Ok, I have the newest version of it, just wanted to make sure that was the same nero not a special eddition made for dvdr's is all
Hide -
Why split it onto 2 dvd's ? just lower the bitrate on the movie and it will fit on one DVD. I have done this several times and compared it with the original. I can't even see the differense. You also keep the Audio quality as if it where the original movie.
RetroSpeC
Spliting DL-DVD at layer break point
By smartel in forum Newbie / General discussionsReplies: 9Last Post: 27th Mar 2012, 12:19 -
spliting a hard drive
By romanstopme in forum ComputerReplies: 11Last Post: 25th Apr 2009, 15:14 -
Spliting Audio Based on silence
By loster in forum AudioReplies: 4Last Post: 30th Aug 2007, 08:27 -
Wrong Size at Spliting
By Flowbax in forum EditingReplies: 3Last Post: 16th Jul 2007, 13:33 -
Spliting Problem
By HannahCapps in forum Newbie / General discussionsReplies: 3Last Post: 11th Jun 2007, 05:41
